Текущее время: 18 янв 2021, 00:52
Начать новую тему Ответить на тему  [ Сообщений: 2643 ]  На страницу Пред.  1 ... 90, 91, 92, 93, 94, 95, 96 ... 106  След.
СообщениеДобавлено: 09 дек 2019, 20:39
SantagenS писал(а):
TTAV134 писал(а):
removed full screen? Yes, is it a problem?
not
but I would like to change at least the height of the window (edit hex\text)
Was the mode removed due to font problems or other reasons?
the width is not adjustable because I saw no interest in having half of the screen empty.
the height is adjustable, i will increase the max height value to 900 in next release.
Actual values:
MaxHeight: 700
MinHeight: 600
Width: 810
СообщениеДобавлено: 10 дек 2019, 18:15
Жду когда появится поддержка N76E003at20
vk.cc/arXpXv
СообщениеДобавлено: 11 дек 2019, 02:31
TTAV134 писал(а):
Q: автоматическое определение компонентов i2c, 93cxx, 95xx, как это реализуется?
R: I can not summarize algorithms that represent hundreds of lines of code and weeks of hard work in a few words.
As far as i know, there are no hidden registers in the components.
Except for some i2c components the method consist to write some datas in bottom or top of the memory to determine the size/pagesize by multiples iterations.
Of course the content of the memory is saved before detect and restored after.
exemple for 95 eeproms:
1- 95 eeproms are sharing opcodes with flash25 family but have no Jedec ID, if component react like a Flash 25 but have no ID, then --> eeprom
2- determine the pagesize by writing datas in multiples iterations
3- with the given pagesize, determine the memory size in multiples iterations
once you have the family (eeprom 95) , pagesize and memory size it is easy to scan the chiplist to find one or more match.
The actual v2.1.0.7 version supports:
- KB901x
- 93C06 to 93C86 (16 bits)
- i2c from 24c01 to 24c2048 (ST M24M02), (25LC515, 25LC1025, AT24RF08 with adapter modification see schemeI2C.gif)
- AT45DBxx family with and without registers (+ old B series without ID) + real page size detection
- EEprom (25/95)
- flash 25 (512 Mbits to 2Gbits still in development)
- ATmega AVR from 64kbits to 2Mbits (Atmega8..Atmega2560) with intel, .hex files import/export.
Muchas gracias por la aclaración, probé la versión 2.1.0.8 link. Me gustó todo, la definición del chip está sucediendo, lo intenté en 24C16 todo está bien. Muchas gracias (TTAV134) por su tiempo y por supuesto (Tifa) por el software en sí. Creo que (Tifa) debería agregar sus desarrollos (TTAV134) a su proyecto. Gracias chicos por el mejor software del mundo!
Огромное спасибо за разъяснения, я попробовал версию version 2.1.0.8 link. Мне все понравилось, определение микросхемы происходит, пробовал на 24С16 все прекрасно. Спасибо огромное вам (TTAV134) за потраченное время и конечно (Tifa) за сам софт. Мне кажется (Tifa) должен добавить ваши наработки (TTAV134) в свой проект. Спасибо парни за лучший софт в мире!
No cambie la ventana principal del programa, ya que todo está muy bien. Edito todo en WinHex es aún más conveniente y para mí no hay problema con las Fuentes, etc.
Не меняйте главное окно программы, там и так все очень хорошо. Я все редактирую в WinHex это даже удобней и для меня нет проблем со шрифтами и.т.д. спасибо.
СообщениеДобавлено: 24 дек 2019, 02:39
Hello
Thanks for the program, the version has been tried asprogrammer_v2.1.0.8 Reading has been a success ZON OTP
Writing problem Script gd25q128b
СообщениеДобавлено: 24 дек 2019, 19:29
Итак подведём итоги:
Программатор USBasp,самодельный, выполнено полное согласование выходных уровней и напряжения питания управляющего контроллера, т.е, при переключении Vpp = 3v3 выходные уровни тоже становятся размахом 3v3, контроллер прошитый файлом mega8_2.0.hex, фьюзы L:EF, H:C9
Отверстия под джемпер "Slow SCK", как анахронизм, были оставлены для стандартной прошивки с https://www.fischl.de/usbasp/ вдруг кому захочется на грабли наступить.
1.JPG [ 108.96 Кб | Просмотров: 2398 ]
Переходник самой простой конструкции, сделанный по рекомендациям подключения м/с памяти в софте. Согласование уровней для м/с памяти с питанием 1v8 сделано на стабилизаторе ХС6206Р182 = 65К5 и резистивно/диодных делителях.
2.JPG [ 83.37 Кб | Просмотров: 2398 ]
Общий вид
3.JPG [ 117.86 Кб | Просмотров: 2398 ]
Прошивка м/с памяти велась с применением софта Asprogrammer_v2.1.0.8, результаты:
24 EEPROM 5v0: 24С08/16/32/64 - ч/с/з/в Ок!
24RF EEPROM 5v0: AT24RF08 - ч/с/з/в Ок!
Подключение м/с памяти AT24RF08 отличается стандартного для 24-й серии. Пины 1,2,3 подымаем с переходника. Между 1-м и 2-м выводами м/с подключаем индуктивность порядка 100uH. Конденсатор не обязательно. 3-й пин подключаем на VCC через резистор 4к7---10к. AT24Rf08 вставляется в слот "24Схх", напряжение питания 5.0 вольт.
25 EEPROM 5v0: 25010/320/640 - ч/с/з/в Ок!
25 flash 3v3:от 128 кB(MX25L1005) до 8mB (W25Q64) - ч/с/з/в Ок!
25 flash 1v8: W25Q32FW, W25Q64FW - ч/с/з/в Ок!
45 Data flash 3v3: AT25DB011/21/41/81/161 - ч/с/з/в Ок!
93 EEPROM 5v0: 93С46/56/66/86 - ч/с/з/в Ок!
95 EEPROM 5v0: 95080 как 25080 - ч/с/з/в Ок!
Единственный недостаток - на больших размерах 25 flash длительное время прошивки.
Последний раз редактировалось fsem 25 дек 2019, 21:32, всего редактировалось 1 раз.
СообщениеДобавлено: 25 дек 2019, 19:00
USBasp полная схема.
USBasp полная схема.JPG [ 67.06 Кб | Просмотров: 2368 ]
USBasp переходник:
USBasp переходник .JPG [ 170.61 Кб | Просмотров: 2368 ]
СообщениеДобавлено: 31 дек 2019, 15:43
kalala писал(а):
Hello
Writing problem, with USBASP, CH341, more details please ????
script is not for OTP (one time programming) but for the 3 SECURITY REGISTERS
dont forget to erase before programming
Написание проблемы ????
скрипт не для OTP (однократное программирование), а для 3-х РЕГИСТРОВ БЕЗОПАСНОСТИ
не забудьте стереть перед программированием
СообщениеДобавлено: 31 дек 2019, 16:03
hello,
New version asprogrammer_v2.1.0.9
Add 93cxx 8bits support (see schemeMW.gif for 8/16 bits jumper)
Better chip detection algorithms.
Minor enhancements, new components.
New firmwares for USBASP, ARDUINO, AVRISP-MKII for 93cxx detection (only mega8_2.2.hex for USBASP is tested)
Последний раз редактировалось TTAV134 22 янв 2020, 00:54, всего редактировалось 1 раз.
СообщениеДобавлено: 01 янв 2020, 11:33
Возможна ли однопроводная поддержка в Далласе?
by google translate
Is it possible to add support for Dallas one-wire eeproms ?
СообщениеДобавлено: 02 янв 2020, 00:27
TTAV134 писал(а):
hello,
not find libusb0.dll
СообщениеДобавлено: 03 янв 2020, 02:11
need to install drivers for usbasp
СообщениеДобавлено: 03 янв 2020, 13:43
hello,
New version asprogrammer_v2.1.0.10
Better EEPROM 25/95 detection algorithm.
(USBASP driver include)
New firmwares for USBASP, ARDUINO, AVRISP-MKII for 93cxx detection (only mega8_2.2.hex for USBASP is tested, fuses L:EF, H:C9)
Последний раз редактировалось TTAV134 22 янв 2020, 14:08, всего редактировалось 4 раз(а).
СообщениеДобавлено: 04 янв 2020, 18:42
TTAV134 писал(а):
hello,
chiplist.xml
<M95010 page="816" size="128" spicmd="95"/>
<M95010R page="816" size="128" spicmd="95"/>
<M95010W page="816" size="128" spicmd="95"/>
<M95020 page="816" size="256" spicmd="95"/>
<M95020R page="816" size="256" spicmd="95"/>
<M95020W page="816" size="256" spicmd="95"/>
<M95040 page="816" size="512" spicmd="95"/>
<M95040R page="816" size="512" spicmd="95"/>
<M95040W page="816" size="512" spicmd="95"/>
опечатка?
СообщениеДобавлено: 04 янв 2020, 18:54
Вот честно, сложно комментировать, но топик преврашается в переговоры для людей, по русски не говорящих. Мне по фигу, я спокойно читаю на анлицком, но раньше они хотя-бы пытались переводить свои посты на русский.
СообщениеДобавлено: 04 янв 2020, 21:39
anakost писал(а):
Вот честно, сложно комментировать, но топик преврашается в переговоры для людей, по русски не говорящих. Мне по фигу, я спокойно читаю на английском, но раньше они хотя-бы пытались переводить свои посты на русский.
это не столько важно (гугл переводчик всегда поможет, или плагин на перевод)
главное что-бы было движение в верном направлении
СообщениеДобавлено: 05 янв 2020, 12:49
главное что-бы было движение в верном направлении[/quote]
1. А мне важно. Я хочу общаться на родном.
2. Где тестировщики? Ждут готовый результат?
3. Чип-лист кишит ошибками. Такое впечатление, что тупо содрали с какого прогера. Как библиотеки в DipTrace. Чего только стоит вот зто: <ATmega8 id="1E9307" page="32" size="8192" pageep="4" sizeep="512" fuses="EF,C9,FF,FF" /> -- здесь фьюзы выставлены под кварц 12mH
Тогда как всегда для ATmega8 id="1E9307" fuses по дефолту ="E1,D9,FF(3F)"
4. При работе с АВР, выбирая любой чип, определяя, видим вот такую картинку
1.JPG [ 85.91 Кб | Просмотров: 1969 ]
5. При подключении 93Сххх на 6-й ноге должен присутствовать ярко выраженный уровень -"0" = 8-ми битному режиму, "1" = 16-ти битному. Напряжение питания этой серии обычно +5 вольт. Желательно, а то при 3v3 идёт ошибка при верификации.
2.JPG [ 46.78 Кб | Просмотров: 1945 ]
Последний раз редактировалось fsem 05 янв 2020, 19:50, всего редактировалось 1 раз.
СообщениеДобавлено: 05 янв 2020, 13:37
опечатка?
1 - алгоритм обнаружил 16 байтов
2 - данные подтвердили это значение.
M95xx_ST.png [ 67.96 Кб | Просмотров: 1963 ]
Последний раз редактировалось TTAV134 05 янв 2020, 16:02, всего редактировалось 1 раз.
СообщениеДобавлено: 05 янв 2020, 15:42
3. Чип-лист кишит ошибками. Такое впечатление, что тупо содрали с какого прогера. Как библиотеки в DipTrace. Чего только стоит вот зто:<ATmega8 id="1E9307" page="32" size="8192" pageep="4" sizeep="512" <ATmega8 id="1E9307" page="32" size="8192" pageep="4" sizeep="512" fuses="EF,C9,FF,FF" /> -- здесь фьюзы выставлены под кварц 12mH
Тогда как всегда для ATmega8 id="1E9307" fuses="E1,D9,FF(3F)"
Как видите, я тупой, невежественный, не специалист по AVR, я использовал значения, предложенные моим программистом WILLEM, и сайт "http://www.engbedded.com/fusecalc", это глупо У каждого пользователя есть свои потребности. Какое лучшее решение, изменить значения по умолчанию или удалить их?
Помимо значений предохранителей, о каких других ошибках вы говорите в списке чипов.
Что касается ложного обнаружения с USBASP, я не мог видеть его с последними версиями прошивки и программного обеспечения. Тем не менее, я поставил двойное обнаружение на компонент AT24RF08C для следующей версии.
прикрепил файл без значений предохранителей по умолчанию.
Последний раз редактировалось TTAV134 22 янв 2020, 14:09, всего редактировалось 3 раз(а).
СообщениеДобавлено: 05 янв 2020, 19:59
TTAV134
Не надо сразу лезть в бутылку. Пока я один занимаюсь тестированием и если не так сказал -извини.
Вообще на сайте: http://www.engbedded.com/fusecalc fuses for m8
м8.JPG [ 77.98 Кб | Просмотров: 1711 ]
Последний раз редактировалось fsem 11 янв 2020, 02:04, всего редактировалось 1 раз.
СообщениеДобавлено: 06 янв 2020, 13:43
fsem писал(а):
...USBasp переходник...
Доброе утро!Подскажите,пожалуйста,у вас в схеме переходников подтягивающие R=4.7K на выводах WP,Hold на панельке 25Схх.На других схемах 330 Ом. Где правильней? А то я уже запутался с переходниками.
СообщениеДобавлено: 06 янв 2020, 14:51
330 ом это минимальное сопротивление (максимум до 5.6ком)
поэтому лучше использовать средний номинал в 2.7ком
в основном нужно для прошивки 25Q чипов
Читаем даташит, например на чип W25Q64FV, и находим пунт Quad Enable (QE),
в котором есть предупреждение:
WARNING: If the /WP or /HOLD pins are tied directly to the power supply or ground during
standard SPI or Dual SPI operation, the QE bit should never be set to a 1.
иными словами контакты /WP/HOLD внутрисхемно замыкаются на /GND
из доработок я бы ещё добавил конденсатор(мкф) по питании чипа
СообщениеДобавлено: 06 янв 2020, 15:27
Спасибо за ответ! И ещё вопрос,если делать переходник 24СХХ+25СХХ,то не мешают ли работе подвязывающие резисторы на SDA,SCL ?
СообщениеДобавлено: 06 янв 2020, 17:14
не должны
СообщениеДобавлено: 19 янв 2020, 19:19
Hello
I have a program FlashCatUSB
I want to run it on a program asprogrammer_v2.1.0.10
Get to know him avrisp-mk2
Programmeur actuel: AVRISP
ID(9F): FFFFFF(ID Iconnu)
ID(90): FFFF(ID Iconnu)
ID(AB): FF(ID Iconnu)
ID(15): FFFF(ID Iconnu)
But I need a shipment atmga32u2
The shipment included in the program is mine USBTINYMKII-16(at90usb162)
СообщениеДобавлено: 20 янв 2020, 20:47
hello,
asprogrammer_v2.1.0.11
new:
support of SPI Nand memories (1G and more),
tests done with Winbond W25N01GV 1G memory and CH341A programmer.
Erase: 3 seconds
Prog: 22 minutes
Read: 21 minutes
Verif: 21 minutes
новые:
поддержка памяти SPI Nand (1G и более),
тесты проведены с памятью Winbond W25N01GV 1G и программатором CH341A.
Стереть: 3 секунды
Прога: 22 минуты
Читать: 21 минута
Вериф: 21 минута
SPI_Nands.png [ 66.42 Кб | Просмотров: 1432 ]
Последний раз редактировалось TTAV134 22 янв 2020, 01:44, всего редактировалось 1 раз.
