Текущее время: 20 янв 2022, 01:00
 Заголовок сообщения: Этот ваш LAMP теперь прекрасно работает на ASP.NET Core
СообщениеДобавлено: 18 ноя 2021, 08:44
с выходом .NET Core программы для .NET (на F# либо С# например) стали мультиплатформенными
например хорошо известный Wordpress используя PeachPie можно запускать под ASP.NET Core.
Peachpie allows for seamless both-way interoperability between PHP and .NET applications. In simpler terms, this means that one can have some parts of an application written in PHP, while other modules are written in .NET and everything will work together as one application. Without Peachpie, connecting these modules is tedious, time-consuming and often risky or producing unnecessary performance overhead.
Benefits Of Running WordPress On ASP.NET Core
Source-less Distribution
Now you never need to worry about copying the PHP sources back and forth. Peachpie compiles the entire source to DLLs which makes lives much easier.
Secure
I personally have quite a lot of experience working with WordPress websites. The amount of security issues and attempts to brute-force attack the login page is pretty high. There are quite a lot of scripts/tools that can automate the entire brute-force process against PHP websites, especially WordPress. With .NET Core into the game, the entire security realm is going to be much tougher to penetrate.
Best of Both Worlds
The richness of WordPress combined with the robustness of .NET.
Blazing Fast WordPress
Yes, it’s quite confusing to realize that Peachpie compiles the WordPress (PHP) to .NET Native assembly and ends up running it much faster than PHP Hosts themselves. Here are the benchmark tests of Peachpie. Pretty Amazing!
Opens up the Hosting World to .NET Core Hosting Providers too
Given the advantages of such an approach, people would now start hosting this variant of WordPress onto .NET Hosts with ease which opens up a huge section of the market.
в контексте происходящей экспансии микрософта, думаю недолго осталось ждать появления Windows 666 с линуксом под капотом.
аля Android - но только Windows.
ржучота.
unirail.org
 Заголовок сообщения: Re: Этот ваш LAMP теперь прекрасно работает на ASP.NET Core
СообщениеДобавлено: 18 ноя 2021, 11:38
Каким же идиотом нужно быть, чтобы что-то хоть немного более-менее важное под мастдайкой запускать? Хочешь, чтобы твои данные стали достоянием общественности, а твой комп — узлом ботнета?
СообщениеДобавлено: 18 ноя 2021, 12:10
cheblin, набрось лучше про микроконтроллеры что-нибудь, про виндовс скучно
Тут вообще скучно стало после того как selevo ушёл
Eddy_Em, а куда dosikus подевался не знаешь?
Не видел его давно не только тут, а вообще нигде
Последний раз редактировалось vt340 18 ноя 2021, 14:00, всего редактировалось 1 раз.
СообщениеДобавлено: 18 ноя 2021, 13:03
скоро, скоро наброшу... но для этого нужно ещё поработать.
unirail.org
СообщениеДобавлено: 18 ноя 2021, 13:25
dosikus сказал, что устал от форумов и решил отойти от них подальше. Хотя изредка кое-где и мелькают его посты.
СообщениеДобавлено: 18 ноя 2021, 13:46
и правильно.
СообщениеДобавлено: 18 ноя 2021, 14:00
Печально
