Текущее время: 23 янв 2021, 20:21
 Заголовок сообщения: Чудит avrdude в Linux (или я).
СообщениеДобавлено: 24 май 2018, 00:24
Не проходит проверка после записи в atmega16, если файл прошивки менее 128 байт.
avrdude: Version 6.3
dd if=/dev/zero of=127b.raw bs=1 count=127
dd if=/dev/zero of=128b.raw bs=1 count=128
avrdude -c avrftdi -p m16 -U flash:w:127b.raw:r
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9403 (probably m16)
avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
         To disable this feature, specify the -D option.
avrdude: erasing chip
avrdude: reading input file "127b.raw"
avrdude: writing flash (128 bytes):
Writing | ################################################## | 100% 0.03s
avrdude: 128 bytes of flash written
avrdude: verifying flash memory against 127b.raw:
avrdude: load data flash data from input file 127b.raw:
avrdude: input file 127b.raw contains 128 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.03s
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0xff != 0x00
avrdude: verification error; content mismatch
avrdude: safemode: Fuses OK (E:FF, H:9A, L:E4)
avrdude done.  Thank you.
avrdude -c avrftdi -p m16 -U flash:w:128b.raw:r
avrdude: reading input file "128b.raw"
avrdude: verifying flash memory against 128b.raw:
avrdude: load data flash data from input file 128b.raw:
avrdude: input file 128b.raw contains 128 bytes
avrdude: 128 bytes of flash verified
С -vvvv после записи выдаёт предупреждение
W avrftdi_flash_write(1081): No suitable byte (!=0xff) for polling found.
W avrftdi_flash_write(1082): Trying to sleep instead, but programming errors may occur.
W avrftdi_flash_write(1083): Be sure to verify programmed memory (no -V option)
При файлах >128 такого предупреждения нет.
Кто-нибудь сталкивался, куда смотреть?
 Заголовок сообщения: Re: Чудит avrdude в Linux (или я).
СообщениеДобавлено: 25 май 2018, 00:13
Починил, но не понимаю как раньше работало.
В avrdude.conf в разделе
# ATmega16
part
id = "m16";
desc = "ATmega16";
есть параметр
memory "flash"
paged = yes;
size = 16384;
page_size = 128;
num_pages = 128;
min_write_delay = 4500;
max_write_delay = 4500;
Вот если сделать
max_write_delay = 9000;
то проверка проходит.
