Текущее время: 21 фев 2020, 06:54
Начать новую тему Ответить на тему  [ Сообщений: 224 ]  На страницу Пред.  1 ... 3, 4, 5, 6, 7, 8, 9  След.
 Заголовок сообщения: Re: SDIO interface for SD card
СообщениеДобавлено: 20 апр 2015, 23:14
It is. But I did actually tried to enable it and got the same result...
That is where this function is being called from.
  // Put the Card in the tranfer mode using cmd7. Bus width can only be changed in transfer mode
  if (((err = sdio_cmd(SDIO_COMMAND_SELECT_CARD, rca<<16, rsp)) == SDIO_LOW_LEVEL_SUCCESS)
    //Change the bus-width with acmd6
  && ((err = sdio_cmd(SDIO_COMMAND_APP_CMD, rca<<16, rsp)) == SDIO_LOW_LEVEL_SUCCESS)
  && ((err = sdio_cmd(SDIO_COMMAND_SET_BUS_WIDTH, SDIO_BUS_WIDTH_4, rsp)) == SDIO_LOW_LEVEL_SUCCESS)) {
    sdio_bus_clk(SDIO_24MHZ);
    sdio_bus_width(SDIO_BUS_WIDTH_4);
    for (ec = 0, arg = 0; arg < 1000; arg++) {
      err = rd_abs_block((uint32_t *)sdio_blk, arg);
      if ((tmp = sdio_cmd(SDIO_COMMAND_SEND_STATUS, rca<<16, NULL)) != SDIO_RESP_OK) break;
      if (err != SDIO_RESP_OK) {
        ec++;
        arg--;
      else {
        for (offs = 0; offs < (CARD_BLOCK_SIZE - sizeof(SIGN)); offs++)
           if (strncmp(&sdio_blk[offs], SIGN, sizeof(SIGN)) == 0) break;
        if (offs < (CARD_BLOCK_SIZE - sizeof(SIGN))) {
          found = true;
          break;
СообщениеДобавлено: 21 апр 2015, 00:52
If HW flow disabled, then only one though: PCB issues. At first, try to switch to 1-bit bus, then decrease bus speed.
Pull-up resistors for each SDIO line must be in range 10k..100k, SDIO_CK doesn't need pull-up. The pull-up resistor for the SDIO_D3 line is already inside the SD card, however its value varies from card to card, you might try to pull-up the SDIO_D3 line with external resistor and disable the internal pull-up by software (ACMD42).
СообщениеДобавлено: 21 апр 2015, 02:22
I'm using original dev boards and their software works - i.e. it is my software at fault.
I also tried 1-bit bus and 400kHz clk. Nothing changes.
Another clue is that sometimes I'm able to read the first block and NEVER anything else.
СообщениеДобавлено: 21 апр 2015, 03:02
That's my ReadBlock procedure, it works on STM32L151 at 32Mhz with 12MHz SDIO bus. With higher bus frequency the overrun errors happens because the MCU does not have time to load data into the SDIO FIFO in time. Maybe it will be helpful.
Show SD_WriteBlock
СообщениеДобавлено: 21 апр 2015, 18:07
Will give a shot. Thanks. I don't see any meaningful difference.
I can read one block only. What needs to be done to read the next block? What confuses me most that when the function is called again it loops forever with bits RXACT and RXFIFOE set and at the same time the FIFOCNT register becomes 0x80...
uint8_t rd_abs_block (uint16_t rca, uint32_t *buf, uint32_t blk) {
  uint8_t    err;
  uint32_t   r1;
//  SDIO->DCTRL = 0;
//  if ((err = sdio_cmd(SDIO_COMMAND_SEND_STATUS, rca<<16, NULL)) != SDIO_LOW_LEVEL_SUCCESS) return err;
  SDIO->DLEN    = CARD_BLOCK_SIZE;
  SDIO->DTIMER  = CARD_BLOCK_SIZE * DATA_RD_TMO_VALUE;
  SDIO->DCTRL   = SDIO_BLK_SIZE_512 | SDIO_DCTRL_RD | SDIO_DCTRL_DTEN;
  if ((err = sdio_cmd(SDIO_COMMAND_READ_BLOCK, blk, NULL)) != SDIO_LOW_LEVEL_SUCCESS) return err;
  do {
    r1 = SDIO->STA;
    if (r1 & SDIO_STA_RXFIFOHF) {
      *buf++ = SDIO->FIFO;
      continue;
    if (r1 & SDIO_STA_DTIMEOUT) {
      SDIO->ICR = SDIO_ICR_CLEAR_ALL;
      return SDIO_LOW_LEVEL_DATA_TMO;
    if (r1 & SDIO_STA_DCRCFAIL) {
      return SDIO_LOW_LEVEL_DCRC_FAIL;
    if (r1 & SDIO_STA_RXOVERR) {
      return SDIO_LOW_LEVEL_RXOVERR;
    if (r1 & SDIO_STA_STBITERR) {
      return SDIO_LOW_LEVEL_START_BIT_ERR;
    if (r1 & SDIO_STA_DBCKEND) {
      while (SDIO->STA & SDIO_STA_RXDAVL) *buf++ = SDIO->FIFO;
      return SDIO_LOW_LEVEL_SUCCESS;
  } while (r1 & SDIO_STA_RXACT);
  return SDIO_LOW_LEVEL_ERR_UNKNOWN;
СообщениеДобавлено: 24 апр 2015, 19:18
Now I have CTIMEOUT fault. Step by step operations are seems to be working. Any advice how to deal with it?
СообщениеДобавлено: 24 апр 2015, 20:31
For multiple-block reading also try to check the SDIO_STA_DATAEND bit.
This value - a timeout measured in SDIO clocks, according to the SD specifications it must be at least 250ms for write and 100ms for read. Maybe you set it to low?
That's my macroses for calculation (SDIO_CLK_DIV_TRAN - SDIO clock divider in the CLKCR register, 48000000 - SDIO clock):
#define SDIO_DATA_R_TIMEOUT           ((uint32_t)((48000000 / (SDIO_CLK_DIV_TRAN + 2) / 1000) * 100)) // Data read timeout is 100ms
#define SDIO_DATA_W_TIMEOUT           ((uint32_t)((48000000 / (SDIO_CLK_DIV_TRAN + 2) / 1000) * 250)) // Date write timeout is 250ms
СообщениеДобавлено: 24 апр 2015, 22:12
And this is mine:
#define SD_CLK                          24000000UL
// RD ~100ms at 24MHz SD clock   */
#define DATA_RD_TMO_VALUE               (100*(SD_CLK/1000))
// WR ~200ms at 24MHz SD clock   */
#define DATA_WR_TMO_VALUE               (200*(SD_CLK/1000))
Yours is better, but for now my task scope is limited.
СообщениеДобавлено: 25 апр 2015, 00:28
Publishing the whole code. If someone sees something suspicious, please let me know.
FYI: I can read Russian, but can type it only from my home machine.
Show Код
Последний раз редактировалось elisey 25 апр 2015, 07:23, всего редактировалось 1 раз.
Большие листинги кода нужно прятать под спойлер
СообщениеДобавлено: 16 июн 2015, 18:35
Привет, обьясните как использовать библиотеку sdio_SD.h (sdio_SD.c).
SD_Error SD_ReadBlock(uint8_t *readbuff, uint32_t ReadAddr, uint16_t BlockSize) // функция чтения одного блока
Что в этой функции нужно указывать в параметре ReadAddr. Номер сектора или все таки какой-то адрес? Как тогда перевести адреса в номера секторов, чтоб удобнее было?
Потом... она возвращает результат типа SD_Error. Чтобы посмотреть мне нужно создавать в программе переменную типа SD_Error ? это же целая структура?
СообщениеДобавлено: 16 июн 2015, 18:49
В теории, для SDSC карточек (SD standard capacity, до 2Gb включительно), адресация идет кратно размеру сектора, т.е. 0, 512, 1024... (если сектор 512байт). Для SDHC,SDXC - адресация поблочно, т.е. 0, 1, 2... В самой же функции может быть сделан автоматический перерасчет адреса под тип карточки, так что не видя нутра функции, однозначного ответа на вопрос об адресе дать нельзя. Так же и про SD_Error - надо смотреть исходники.
СообщениеДобавлено: 16 июн 2015, 19:06
LonelyWolf, щас вроде запустил. Инициализация SDIO, SD, проходит SD_OK . А чтение блока 0x03 SD_CMD_RSP_TIMEOUT.
Для меня пока трудно разобраться, неужели для работы нужно столько телодвижений? Я заметил что используется 1bit передача, или это только команда?!
Все эти готовые библиотеки, SPL тоже, вводят меня в ступор , я лучше бы писал названия регистров...
Последний раз редактировалось elisey 16 июн 2015, 20:14, всего редактировалось 1 раз.
СообщениеДобавлено: 16 июн 2015, 19:56
Парни - кончайте этот онанизм!
Качайте новый куб, за 5 минут рабочий проект получите, с преферансом и поэтессами!
Потом можете его код ковырять до скончания времён!
СообщениеДобавлено: 16 июн 2015, 21:01
По изначальному вопросу, из кода
  if (CardType == SDIO_HIGH_CAPACITY_SD_CARD)
    BlockSize = 512;
    ReadAddr /= 512;
видно, что адрес надо задавать кратным размеру блока, т.е. 0, 512, 1024... и оно само переведет адрес в номер блока для SDHC карты. В любом случае адрес 0 должен читаться.
Карта инициализируется в 1bit режиме, т.е. задействована только одна линия для передачи данных D0. После инициализации карту можно перевести в 4-bit режим, когда будут задействованы D0..D3 линии.
А точно инициализация проходит успешно? Параметры карты верно определяются? Ну и обычный вопрос еще в таких случаях: на линиях SD_D0, SD_CMD есть подтяжка к питанию на 47кОм (не 4.7к!)?
А также набором веселых глюков из-за сырости кода, ответственного за SDIO...
СообщениеДобавлено: 16 июн 2015, 22:35
Не удобненько тут у вас цитировать фрагменты(
LonelyWolf, я так и не понял, мне адрес нужно указывать не как номер сектора, а именно адрес? Например я хочу 500-тый сектор, значит писать 500 * 512 ?
Подтяжки стоят везде 11К ом, причем даже на тактовой ножке, сейчас уберу... Инициализация вроде успешна...
В коментариях то что пишет окно Watch:
volatile SD_Error temp;//Это я создал переменную типа SD_Error.
SD_DeInit();
SD_Init();
temp =SD_PowerON();// Temp 0x2A SD_OK
temp = SD_InitializeCards();//Temp 0x2A SD_OK
temp = SD_ReadBlock(&BUFFER[0], 550, 512);// Temp 0x03 SD_CMD_RSP_TIMEOUT
СообщениеДобавлено: 16 июн 2015, 23:45
Да, именно так.
Не помешало бы в этом убедиться. Судя по приведенному коду ReadBlock, это нечто из SPL или CubeMX. Значит там должна быть перменная, содержащая структуру CSD. При инициализации карты в эту структуру забиваются её параметры. Стоит убедиться, что туда корректные данные забиты (объем карты, её тип и чего там еще можно глянуть).
MIG29 писал(а):
0x2A SD_OK
Странное значение для SD_OK, все время в поделках SPL/Cube оно нулем было.
Update: хотя сейчас нашел на гите некий проект, где есть bsp_sdio_sd.с/bsp_sdio_sd.h, там да, SD_OK явно не задан и он вполне может быть равен 0x2A.
  * @file    stm32_eval_sdio_sd.c
  * @author  MCD Application Team
  * @version V4.4.0
  * @date    31-December-2010
Последний раз редактировалось LonelyWolf 17 июн 2015, 00:08, всего редактировалось 1 раз.
СообщениеДобавлено: 17 июн 2015, 00:07
LonelyWolf, вот все варианты ошибок , 42 (0x2A) элемент как раз SD_OK.
Как думаете, мне проще написать свой код или пробовать ковырять этот? Мне нужно всего лишь чтение блоков (одиночных, а лучше сразу несколько)....
СообщениеДобавлено: 17 июн 2015, 00:12
В этом вопросе трудно советовать. Я, в свое время, ковырялся в одной из версий этой библиотеки из SPL, в результате написал свою реализацию.
А вот почему ReadBlock возвращает таймаут - дебажить надо. Смотреть в каком месте возникает этот самый таймаут и там уже кумекать. Опять же, повторюсь: неплохо бы удостовериться, что карта инициализируется верно, что ее параметры читаются корректно и все такое.
СообщениеДобавлено: 17 июн 2015, 22:01
LonelyWolf, удалось считывать 1 сектор. При попытке использовать поблочное чтение Keil зависает в размышлениях на долгие минуты (прокручивает что то с DMA).
Для поблочного чтения нужен буфер размером с сумму всех блоков считаных данных?
Моя задача такая, считывать блоки как можно быстрее и запихивать определенные байты в определеные регистры сравнения таймеров...
Upd:
Функция чтения блока зависает на манипуляциях с DMA.
Как я понял бесконечно ожидается флаг завершения передачи TCIF4 (Channel 4 transfer complete flag)...
При этом выставлен флаг "половинной передачи" HTIF4 (Channel 4 Half transfer complete flag) и GIF4 (Channel 4 Global Interrupt flag) тоже выставлен.
Программа зависает в этом месте на долгие минуты, дольше не ждал...
while ((SD_DMAEndOfTransferStatus() == RESET) && (TransferEnd == 0) && (TransferError == SD_OK)) {}
Что особенно не понятно, то это происходит только при чтении определенного сектора. Например 801 в порядке. 807 наотрез зависает...
СообщениеДобавлено: 21 июн 2015, 23:29
Помогите! Не понятно и не работает драйвер! Одни блоки считать может на других зависает! Как работать с карточкой? В готовых драйверах не понятно написано!
else if (DeviceMode == SD_DMA_MODE)
    SDIO_ITConfig(SDIO_IT_DCRCFAIL | SDIO_IT_DTIMEOUT | SDIO_IT_DATAEND | SDIO_IT_RXOVERR | SDIO_IT_STBITERR, ENABLE);
    SDIO_DMACmd(ENABLE);
    SD_LowLevel_DMA_RxConfig((uint32_t *)readbuff, BlockSize);
    if (TransferError != SD_OK)
      return(TransferError);
Что тут делают, к примеру, TransferEnd и TransferError? Каким макаром они могут измениться? Где хоть один обработчик прерывания у этого драйвера?
Не врубаюсь в работу SD и чипа STM32F103 =(
СообщениеДобавлено: 22 июн 2015, 00:53
Очень исчерпывающее объяснение проблемы, как помочь?
Читать документ под названием "SD simplified specifications", вникать в протокол и команды.
В данном случае они должны изменяться в обработчиках прерываний от DMA и SDIO.
СообщениеДобавлено: 22 июн 2015, 01:27
LonelyWolf, в драйвере sdio_sd.c нет таких обработчиков! Что это значит?
Я с карточкой более менее понимаю. Инициализация, считывание там какой то ерунды CSD . Указать размер блока, собственно послать команду считывания блока.
Эта схема более менее понятна. А дальше как надо считывать из буфера? Где ставится "на паузу" тактирование флешки? Какая разница между 3 режимами обработки принятых данных (Polling, Interrupt, DMA) ?
СообщениеДобавлено: 22 июн 2015, 02:26
Да как во всей периферии:
- Polling
HAL_PERIPH_Start (params);
while(1){
    if ( Periph_Some_One() ){
        Do_SomeThing();
- Interrupt
HAL_PERIPH_Start_IT (params);
void Periph_IRQHandler(void){
    Do_SomeThing();
- DMA
HAL_PERIPH_Start_DMA(params);
void DMAx_StreamY_IRQHandler(void){
    Do_SomeThing();
На мой взгляд Interrupt от DMA мало чем отличается. В обоих случаях реакция на что-то через прерывание идет.
СообщениеДобавлено: 22 июн 2015, 03:01
Hamper,
Вот кусочек из драйвера.
Из FIFO берется по 32 бита и кладется в мой буфер, "отступая" по 8x8 (Буфер обьявлен как ссылка uint8_t). Совсем не понимаю , поправьте!
И еще один вопрос как FIFO узнаёт что нужно подгрузить "новые" данные? Как узнает что нужно начать это делать и когда закончить? Прерываниями вроде не пахнет...
СообщениеДобавлено: 22 июн 2015, 03:02
На сайте ST есть такая штука как "STM32F10x standard peripheral library", ищется по кодовой фразе "STSW-STM32054"
http://www.st.com/web/catalog/tools/FM147/CL1794/SC961/SS1743/LN1939/PF257890#
В ней лежит последняя версия этого самого "драйвера" и есть примеры использования. Можно скачать и изучать до полного просветления ;)
На "паузу" тактирование ставится либо автоматом (включен power saving mode в SDIO) либо вручную битом в регистре SDIO.
По режимам, если грубо:
polling - программа в основном цикле опрашивает регистры SDIO. критичная ко времени штука, например на STM32L1 на частоте 32МГц более 8МГц из SDIO выжать неспособна, из-за того, что просто не успеет подгружать/выгружать данные в SDIO
interrupt - все работает на прерываниях SDIO. пришли данные - сработало прерывание, ушла команда - прерывание и т.д.
DMA - то же, что и предыдущий режим, но передача данных в/из SDIO идет средствами DMA, а программа занимается своими делами. как произошло какое-нибудь событие от SDIO (ошибка или окончание передачи) - срабатывает прерывание. точно так же прерывание от DMA об окончании передачи. в этих обработчиках и должны выставляться флаги TransferEnd и TransferError.
FIFO у SDIO - это 32 32-битных ячейки памяти. Флаг RXFIFOHF означает, что 8 или более ячеек FIFO содержат принятые данные. Поэтому приведенный код ожидает установки данного флага и читает 8 ячеек (8х4 байт). tempbuf скорее всего считает не байты, а слова, т.е. реальное количество прочитанных байт будет в 4 раза больше, чем значение tempbuf.
Если не успеть выгрести данные из FIFO, то случится ошибка OVERRUN (SDIO_FLAG_RXOVERR) и обмен с карточкой остановится.
