Текущее время: 17 май 2021, 18:43
 Заголовок сообщения: LwIP + NXP + freeRtos трабл
СообщениеДобавлено: 21 май 2013, 23:37
LwIP + NXP1769 + freeRtos, HTTP server падает через определённое количество запросов. Количество запросов прямопропорцианально от PBUF_POOL_SIZE. Если в http сервере оставить только слушатель, то система работает.
Файл настройки lwip.
#ifndef __LWIPOPTS_H__
#define __LWIPOPTS_H__
#include <limits.h>
/* Define platform endianness (might already be defined) */
#define BYTE_ORDER LITTLE_ENDIAN
/* Using the Lite Ethernet IP. */
#define XLWIP_CONFIG_INCLUDE_EMACLITE 1
/* SSI options. */
#define TCPIP_THREAD_NAME              "tcpip"
#define LWIP_HTTPD_MAX_TAG_NAME_LEN    20
#define LWIP_HTTPD_MAX_TAG_INSERT_LEN    1500
#define TCPIP_THREAD_PRIO             configLWIP_TASK_PRIORITY
#define TCPIP_THREAD_STACKSIZE          conifgTCPIP_TASK_STACK_SIZE
/* MBox sizes cannot be zero, which is their default. */
#define DEFAULT_TCP_RECVMBOX_SIZE       5
#define DEFAULT_ACCEPTMBOX_SIZE       5
#define TCPIP_MBOX_SIZE                10
/* FreeRTOS is used. */
#define NO_SYS                     0
/* Sockets are used for the command interpreter. */
#define LWIP_SOCKET                     1
/* In this example, only the raw API is used. */
#define LWIP_NETCONN                    1
/* SNMP and IGMP are not required by this simple demo.  ICMP is always useful
though. */
#define LWIP_SNMP                  0
#define LWIP_IGMP                  0
#define LWIP_ICMP                  1
/* DNS is not going to be used as this is a simple local example. */
#define LWIP_DNS                  0
#define LWIP_HAVE_LOOPIF            0
#define TCP_LISTEN_BACKLOG            1
#define LWIP_SO_RCVTIMEO               1
#define LWIP_SO_RCVBUF                1
#undef LWIP_DEBUG
#ifdef LWIP_DEBUG
   #define LWIP_DBG_MIN_LEVEL          0
   #define PPP_DEBUG               LWIP_DBG_OFF
   #define MEM_DEBUG               LWIP_DBG_ON
   #define MEMP_DEBUG               LWIP_DBG_ON
   #define PBUF_DEBUG               LWIP_DBG_ON
   #define API_LIB_DEBUG            LWIP_DBG_OFF
   #define API_MSG_DEBUG            LWIP_DBG_OFF
   #define TCPIP_DEBUG               LWIP_DBG_OFF
   #define NETIF_DEBUG               LWIP_DBG_OFF
   #define SOCKETS_DEBUG            LWIP_DBG_OFF
   #define DNS_DEBUG               LWIP_DBG_OFF
   #define AUTOIP_DEBUG            LWIP_DBG_OFF
   #define DHCP_DEBUG               LWIP_DBG_OFF
   #define IP_DEBUG               LWIP_DBG_OFF
   #define IP_REASS_DEBUG            LWIP_DBG_OFF
   #define ICMP_DEBUG               LWIP_DBG_OFF
   #define IGMP_DEBUG               LWIP_DBG_OFF
   #define UDP_DEBUG               LWIP_DBG_OFF
   #define TCP_DEBUG               LWIP_DBG_OFF
   #define TCP_INPUT_DEBUG            LWIP_DBG_OFF
   #define TCP_OUTPUT_DEBUG         LWIP_DBG_OFF
   #define TCP_RTO_DEBUG            LWIP_DBG_OFF
   #define TCP_CWND_DEBUG            LWIP_DBG_OFF
   #define TCP_WND_DEBUG            LWIP_DBG_OFF
   #define TCP_FR_DEBUG            LWIP_DBG_OFF
   #define TCP_QLEN_DEBUG            LWIP_DBG_OFF
   #define TCP_RST_DEBUG            LWIP_DBG_OFF
#endif
#define LWIP_DBG_TYPES_ON            (LWIP_DBG_ON|LWIP_DBG_TRACE|LWIP_DBG_STATE|LWIP_DBG_FRESH|LWIP_DBG_HALT)
/* ---------- Memory options ---------- */
/* MEM_ALIGNMENT: should be set to the alignment of the CPU for which
   lwIP is compiled. 4 byte alignment -> define MEM_ALIGNMENT to 4, 2
   byte alignment -> define MEM_ALIGNMENT to 2. */
/* MSVC port: intel processors don't need 4-byte alignment,
   but are faster that way! */
#define MEM_ALIGNMENT         4
/* MEM_SIZE: the size of the heap memory. If the application will send
a lot of data that needs to be copied, this should be set high. */
#define MEM_SIZE            ( 2 * 1024 )
/* MEMP_NUM_PBUF: the number of memp struct pbufs. If the application
   sends a lot of data out of ROM (or other static memory), this
#define MEMP_NUM_PBUF         5
/* MEMP_NUM_RAW_PCB: the number of UDP protocol control blocks. One
   per active RAW "connection". */
#define LWIP_RAW            0
#define MEMP_NUM_RAW_PCB      0
/* MEMP_NUM_UDP_PCB: the number of UDP protocol control blocks. One
   per active UDP "connection". */
#define MEMP_NUM_UDP_PCB      2
/* MEMP_NUM_TCP_PCB: the number of simulatenously active TCP
   connections. */
#define MEMP_NUM_TCP_PCB      10
/* MEMP_NUM_TCP_PCB_LISTEN: the number of listening TCP
   connections. */
#define MEMP_NUM_TCP_PCB_LISTEN 2
/* MEMP_NUM_TCP_SEG: the number of simultaneously queued TCP
   segments. */
#define MEMP_NUM_TCP_SEG      5
/* MEMP_NUM_SYS_TIMEOUT: the number of simulateously active
   timeouts. */
#define MEMP_NUM_SYS_TIMEOUT   10
/* The following four are used only with the sequential API and can be
   set to 0 if the application only will use the raw API. */
/* MEMP_NUM_NETBUF: the number of struct netbufs. */
#define MEMP_NUM_NETBUF         0
/* MEMP_NUM_NETCONN: the number of struct netconns. */
#define MEMP_NUM_NETCONN        10
/* MEMP_NUM_TCPIP_MSG_*: the number of struct tcpip_msg, which is used
   for sequential API communication and incoming packets. Used in
   src/api/tcpip.c. */
#define MEMP_NUM_TCPIP_MSG_API   4
#define MEMP_NUM_TCPIP_MSG_INPKT 4
#define MEMP_NUM_ARP_QUEUE      5
/* ---------- Pbuf options ---------- */
/* PBUF_POOL_SIZE: the number of buffers in the pbuf pool. */
#define PBUF_POOL_SIZE         10
/* PBUF_POOL_BUFSIZE: the size of each pbuf in the pbuf pool. */
#define PBUF_POOL_BUFSIZE      375
/* PBUF_LINK_HLEN: the number of bytes that should be allocated for a
   link level header. */
#define PBUF_LINK_HLEN         16
/** SYS_LIGHTWEIGHT_PROT
* define SYS_LIGHTWEIGHT_PROT in lwipopts.h if you want inter-task protection
* for certain critical regions during buffer allocation, deallocation and memory
* allocation and deallocation.
#define SYS_LIGHTWEIGHT_PROT   (NO_SYS==0)
/* ---------- TCP options ---------- */
#define LWIP_TCP            1
#define TCP_TTL               255
/* Controls if TCP should queue segments that arrive out of
   order. Define to 0 if your device is low on memory. */
#define TCP_QUEUE_OOSEQ         0
/* TCP Maximum segment size. */
#define TCP_MSS               1460
/* TCP sender buffer space (bytes). */
#define TCP_SND_BUF            ( TCP_MSS * 2 )
/* TCP sender buffer space (pbufs). This must be at least = 2 *
   TCP_SND_BUF/TCP_MSS for things to work. */
#define TCP_SND_QUEUELEN      (4 * TCP_SND_BUF/TCP_MSS)
/* TCP writable space (bytes). This must be less than or equal
   to TCP_SND_BUF. It is the amount of space which must be
   available in the tcp snd_buf for select to return writable */
#define TCP_SNDLOWAT         (TCP_SND_BUF/2)
/* TCP receive window. */
#define TCP_WND               ( PBUF_POOL_SIZE * PBUF_POOL_BUFSIZE )
/* Maximum number of retransmissions of data segments. */
#define TCP_MAXRTX            12
/* Maximum number of retransmissions of SYN segments. */
#define TCP_SYNMAXRTX         4
/* ---------- ARP options ---------- */
#define LWIP_ARP            1
#define ARP_TABLE_SIZE         10
#define ARP_QUEUEING         1
/* ---------- IP options ---------- */
/* Define IP_FORWARD to 1 if you wish to have the ability to forward
   IP packets across network interfaces. If you are going to run lwIP
   on a device with only one network interface, define this to 0. */
#define IP_FORWARD            0
/* IP reassembly and segmentation.These are orthogonal even
* if they both deal with IP fragments */
#define IP_REASSEMBLY         0
#define IP_REASS_MAX_PBUFS      10
#define MEMP_NUM_REASSDATA      10
#define IP_FRAG               0
/* ---------- ICMP options ---------- */
#define ICMP_TTL            255
/* ---------- DHCP options ---------- */
/* Define LWIP_DHCP to 1 if you want DHCP configuration of
   interfaces. */
#define LWIP_DHCP            0
/* 1 if you want to do an ARP check on the offered address
   (recommended). */
#define DHCP_DOES_ARP_CHECK      (LWIP_DHCP)
/* ---------- AUTOIP options ------- */
#define LWIP_AUTOIP            0
#define LWIP_DHCP_AUTOIP_COOP   (LWIP_DHCP && LWIP_AUTOIP)
/* ---------- UDP options ---------- */
#define LWIP_UDP            0
#define LWIP_UDPLITE         0
#define UDP_TTL               255
/* ---------- Statistics options ---------- */
#define LWIP_STATS            1
#define LWIP_STATS_DISPLAY      1
#if LWIP_STATS
   #define LINK_STATS            1
   #define IP_STATS            1
   #define ICMP_STATS            0
   #define IGMP_STATS            0
   #define IPFRAG_STATS         1
   #define UDP_STATS            0
   #define TCP_STATS            1
   #define MEM_STATS            1
   #define MEMP_STATS            1
   #define PBUF_STATS            1
   #define SYS_STATS            1
#endif /* LWIP_STATS */
/* ---------- PPP options ---------- */
#define PPP_SUPPORT          0     /* Set > 0 for PPP */
#if PPP_SUPPORT
   #define NUM_PPP               1     /* Max PPP sessions. */
   /* Select modules to enable.  Ideally these would be set in the makefile but
    * we're limited by the command line length so you need to modify the settings
    * in this file.
   #define PPPOE_SUPPORT         1
   #define PPPOS_SUPPORT         1
   #define PAP_SUPPORT            1     /* Set > 0 for PAP. */
   #define CHAP_SUPPORT         1     /* Set > 0 for CHAP. */
   #define MSCHAP_SUPPORT         0     /* Set > 0 for MSCHAP (NOT FUNCTIONAL!) */
   #define CBCP_SUPPORT         0     /* Set > 0 for CBCP (NOT FUNCTIONAL!) */
   #define CCP_SUPPORT            0     /* Set > 0 for CCP (NOT FUNCTIONAL!) */
   #define VJ_SUPPORT            1     /* Set > 0 for VJ header compression. */
   #define MD5_SUPPORT            1     /* Set > 0 for MD5 (see also CHAP) */
#endif /* PPP_SUPPORT */
#endif /* __LWIPOPTS_H__ */
 Заголовок сообщения: Re: LwIP + NXP + freeRtos трабл
СообщениеДобавлено: 22 май 2013, 00:04
очевидно, что или память течет, или сильно фрагментируется. хотя и не 100%. лучше бы вы, когда оно упало, покопались по памяти и посмотрели где что и в каком состоянии. и почему упало.
СообщениеДобавлено: 22 май 2013, 00:52
Спасибо за ответ.
Сам склоняюсть в варианту с утечкой памяти, просмотрел low level там где я драйверописанием занимался, там очитска памяти производится норм, в таске http сервер тоже производится очистка буфера. При каждом создании нового нетбуффера идёт смещение адресного пространства выделяемого динамически. Как отловить утечку в этом всём пока понять не могу.
СообщениеДобавлено: 22 май 2013, 02:09
а если вместо хттп-сервера повесить просто эхо какое-нить? так хотя бы будет ясно, это именно сервер гонит или что-то еще. если сервер - смотреть его логику и искать, например, функции, где есть выходы без освобождения памяти...
СообщениеДобавлено: 18 апр 2015, 06:18
извините, решили проблему? )
