Текущее время: 05 июн 2020, 13:29
 Заголовок сообщения: nrf51822 s130 v2 и рабочий проект для Segger
СообщениеДобавлено: 18 янв 2018, 05:43
Вот есть у меня файл главный от сеггера.
<!DOCTYPE CrossStudio_Project_File>
<solution Name="nrf51-ble-tutorial-characteristic" target="8" version="2">
  <project Name="nrf51-ble-tutorial-characteristic">
    <configuration
      Name="Common"
      arm_architecture="v6M"
      arm_core_type="Cortex-M0"
      arm_endian="Little"
      arm_fp_abi="Soft"
      arm_fpu_type="None"
      arm_simulator_memory_simulation_parameter="RX 00000000,00040000,FFFFFFFF;RWX 20000000,00008000,CDCDCDCD"
      arm_target_device_name="nRF51422_xxAC"
      arm_target_interface_type="SWD"
      debug_start_from_entry_point_symbol="No"
      debug_target_connection="J-Link"
      linker_section_placement_file="$(StudioDir)/targets/Cortex_M/flash_placement.xml"
      linker_section_placements_segments="FLASH RX 0x00000000 0x00040000;SRAM RWX 0x20000000 0x00008000"
      project_directory=""
      project_type="Executable" />
    <folder Name="Internal Files">
      <file file_name="$(StudioDir)/source/thumb_crt0.s" />
      <file file_name="../../../../../../components/toolchain/system_nrf51.c" />
      <file file_name="../../../../../../components/toolchain/embedded_studio/ses_nrf51_startup.s" />
    </folder>
    <configuration
      Name="nrf51422_xxac_s130"
      c_preprocessor_definitions="BLE_STACK_SUPPORT_REQD;S130;BOARD_PCA10028;NRF_LOG_USES_UART=1;SOFTDEVICE_PRESENT;NRF51;SWI_DISABLE0;DEBUG"
      c_user_include_directories="$(PackagesDir)/CMSIS_4/CMSIS/Include;../../../config/ble_app_template_s130_pca10028;../../../config;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/common;../../../../../../components/ble/device_manager;../../../../../../components/drivers_nrf/common;../../../../../../components/drivers_nrf/config;../../../../../../components/drivers_nrf/delay;../../../../../../components/drivers_nrf/gpiote;../../../../../../components/drivers_nrf/hal;../../../../../../components/drivers_nrf/pstorage;../../../../../../components/drivers_nrf/uart;../../../../../../components/libraries/button;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/fstorage/config;../../../../../../components/libraries/sensorsim;../../../../../../components/libraries/timer;../../../../../../components/libraries/trace;../../../../../../components/libraries/uart;../../../../../../components/libraries/util;../../../../../../components/softdevice/common/softdevice_handler;../../../../../../components/softdevice/s130/headers;../../../../../../components/softdevice/s130/headers/nrf51;../../../../../../components/toolchain;../../../../../bsp;../../../../../../components/libraries/fifo" />
    <folder Name="Application">
      <file file_name="../../../main.c" />
      <file file_name="../../../our_service.c" />
    </folder>
    <folder Name="Board Support">
      <file file_name="../../../../../bsp/bsp.c" />
      <file file_name="../../../../../bsp/bsp_btn_ble.c" />
    </folder>
    <folder Name="Documentation">
      <file file_name="../../../Abstract.txt" />
      <file file_name="../../../license.txt" />
    </folder>
    <folder Name="nRF_BLE">
      <file file_name="../../../../../../components/ble/common/ble_advdata.c" />
      <file file_name="../../../../../../components/ble/ble_advertising/ble_advertising.c" />
      <file file_name="../../../../../../components/ble/common/ble_conn_params.c" />
      <file file_name="../../../../../../components/ble/common/ble_srv_common.c" />
      <file file_name="../../../../../../components/ble/device_manager/device_manager_peripheral.c" />
    </folder>
    <folder Name="nRF_Drivers">
      <file file_name="../../../../../../components/drivers_nrf/delay/nrf_delay.c" />
      <file file_name="../../../../../../components/drivers_nrf/common/nrf_drv_common.c" />
      <file file_name="../../../../../../components/drivers_nrf/gpiote/nrf_drv_gpiote.c" />
      <file file_name="../../../../../../components/drivers_nrf/uart/nrf_drv_uart.c" />
      <file file_name="../../../../../../components/drivers_nrf/pstorage/pstorage.c" />
    </folder>
    <folder Name="nRF_Libraries">
      <file file_name="../../../../../../components/libraries/button/app_button.c" />
      <file file_name="../../../../../../components/libraries/util/app_error.c" />
      <file file_name="../../../../../../components/libraries/util/app_error_weak.c" />
      <file file_name="../../../../../../components/libraries/timer/app_timer.c" />
      <file file_name="../../../../../../components/libraries/trace/app_trace.c" />
      <file file_name="../../../../../../components/libraries/util/app_util_platform.c" />
      <file file_name="../../../../../../components/libraries/fstorage/fstorage.c" />
      <file file_name="../../../../../../components/libraries/util/nrf_assert.c" />
      <file file_name="../../../../../../components/libraries/util/nrf_log.c" />
      <file file_name="../../../../../../components/libraries/uart/retarget.c" />
      <file file_name="../../../../../../components/libraries/sensorsim/sensorsim.c" />
      <file file_name="../../../../../../components/libraries/fifo/app_fifo.c" />
      <file file_name="../../../../../../components/libraries/uart/app_uart_fifo.c" />
    </folder>
    <folder Name="nRF_Segger_RTT">
      <file file_name="../../../../../../external/segger_rtt/RTT_Syscalls_KEIL.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT.c" />
      <file file_name="../../../../../../external/segger_rtt/SEGGER_RTT_printf.c" />
    </folder>
    <folder Name="nRF_SoftDevice">
      <file file_name="../../../../../../components/softdevice/s130/doc/s130_nrf51_2.0.0_licence_agreement.txt" />
      <file file_name="../../../../../../components/softdevice/common/softdevice_handler/softdevice_handler.c" />
    </folder>
    <folder Name="::CMSIS" />
    <folder Name="::Device" />
    <configuration
      JLinkLogFileName="/temp123.log"
      Name="nrf51822_xxac_s130"
      arm_endian="Little"
      arm_fp_abi="Soft"
      arm_fpu_type="None"
      arm_simulator_memory_simulation_parameter="RX 00000000,00040000,FFFFFFFF;RWX 20000000,00004000,CDCDCDCD"
      arm_target_device_name="nRF51822_xxAA"
      c_preprocessor_definitions="BOARD_PCA10028;BLE_STACK_SUPPORT_REQD;S130;SOFTDEVICE_PRESENT;NRF51"
      c_user_include_directories="$(PackagesDir)/CMSIS_4/CMSIS/Include;../../../config/ble_app_beacon_s130_pca10028;../../../config\;../../../../../../components/ble/common;../../../../../../components/drivers_nrf/common;../../../../../../components/drivers_nrf/config;../../../../../../components/drivers_nrf/delay;../../../../../../components/drivers_nrf/gpiote;../../../../../../components/drivers_nrf/hal;../../../../../../components/drivers_nrf/uart;../../../../../../components/libraries/button;../../../../../../components/libraries/fifo;../../../../../../components/libraries/timer;../../../../../../components/libraries/uart;../../../../../../components/libraries/util;../../../../../../components/softdevice/common/softdevice_handler;../../../../../../components/softdevice/s130/headers;../../../../../../components/softdevice/s130/headers/nrf51;../../../../../../components/toolchain;../../../../../bsp;../../../../../../external/segger_rtt;../../../config;../../../../../../components;../../../../../../components/ble/ble_advertising;../../../../../../components/ble/ble_dtm;../../../../../../components/ble/ble_racp;../../../../../../components/ble/ble_services/ble_ancs_c;../../../../../../components/ble/ble_services/ble_ans_c;../../../../../../components/ble/ble_services/ble_bas;../../../../../../components/ble/ble_services/ble_bas_c;../../../../../../components/ble/ble_services/ble_cscs;../../../../../../components/ble/ble_services/ble_cts_c;../../../../../../components/ble/ble_services/ble_dfu;../../../../../../components/ble/ble_services/ble_dis;../../../../../../components/ble/ble_services/ble_gls;../../../../../../components/ble/ble_services/ble_hids;../../../../../../components/ble/ble_services/ble_hrs;../../../../../../components/ble/ble_services/ble_hrs_c;../../../../../../components/ble/ble_services/ble_hts;../../../../../../components/ble/ble_services/ble_ias;../../../../../../components/ble/ble_services/ble_ias_c;../../../../../../components/ble/ble_services/ble_lbs;../../../../../../components/ble/ble_services/ble_lbs_c;../../../../../../components/ble/ble_services/ble_lls;../../../../../../components/ble/ble_services/ble_nus;../../../../../../components/ble/ble_services/ble_nus_c;../../../../../../components/ble/ble_services/ble_rscs;../../../../../../components/ble/ble_services/ble_rscs_c;../../../../../../components/ble/ble_services/ble_tps;../../../../../../components/ble/common;../../../../../../components/ble/device_manager;../../../../../../components/ble/nrf_ble_qwr;../../../../../../components/ble/peer_manager;../../../../../../components/boards;../../../../../../components/device;../../../../../../components/drivers_nrf/clock;../../../../../../components/drivers_nrf/common;../../../../../../components/drivers_nrf/comp;../../../../../../components/drivers_nrf/delay;../../../../../../components/drivers_nrf/gpiote;../../../../../../components/drivers_nrf/hal;../../../../../../components/drivers_nrf/i2s;../../../../../../components/drivers_nrf/lpcomp;../../../../../../components/drivers_nrf/pdm;../../../../../../components/drivers_nrf/power;../../../../../../components/drivers_nrf/pstorage;../../../../../../components/drivers_nrf/ppi;../../../../../../components/drivers_nrf/pwm;../../../../../../components/drivers_nrf/qdec;../../../../../../components/drivers_nrf/rng;../../../../../../components/drivers_nrf/rtc;../../../../../../components/drivers_nrf/saadc;../../../../../../components/drivers_nrf/spi_master;../../../../../../components/drivers_nrf/spi_slave;../../../../../../components/drivers_nrf/swi;../../../../../../components/drivers_nrf/timer;../../../../../../components/drivers_nrf/twi_master;../../../../../../components/drivers_nrf/twis_slave;../../../../../../components/drivers_nrf/uart;../../../../../../components/drivers_nrf/usbd;../../../../../../components/drivers_nrf/wdt;../../../../../../components/libraries/bsp;../../../../../../components/libraries/button;../../../../../../components/libraries/crc16;../../../../../../components/libraries/crc32;../../../../../../components/libraries/csense;../../../../../../components/libraries/csense_drv;../../../../../../components/libraries/ecc;../../../../../../components/libraries/experimental_section_vars;../../../../../../components/libraries/fds;../../../../../../components/libraries/fifo;../../../../../../components/libraries/fstorage;../../../../../../components/libraries/fstorage/config;../../../../../../components/libraries/gpiote;../../../../../../components/libraries/hardfault;../../../../../../components/libraries/hci;../../../../../../components/libraries/led_softblink;../../../../../../components/libraries/log;../../../../../../components/libraries/log/src;../../../../../../components/libraries/low_power_pwm;../../../../../../components/libraries/mem_manager;../../../../../../components/libraries/pwm;../../../../../../components/libraries/queue;../../../../../../components/libraries/scheduler;../../../../../../components/libraries/slip;../../../../../../components/libraries/strerror;../../../../../../components/libraries/timer;../../../../../../components/libraries/trace;../../../../../../components/libraries/twi;../../../../../../components/libraries/uart;../../../../../../components/libraries/usbd;../../../../../../components/libraries/usbd/class/audio;../../../../../../components/libraries/usbd/class/cdc;../../../../../../components/libraries/usbd/class/cdc/acm;../../../../../../components/libraries/usbd/class/hid;../../../../../../components/libraries/usbd/class/hid/generic;../../../../../../components/libraries/usbd/class/hid/kbd;../../../../../../components/libraries/usbd/class/hid/mouse;../../../../../../components/libraries/usbd/class/msc;../../../../../../components/libraries/usbd/config;../../../../../../components/libraries/util;../../../../../../components/softdevice/common/softdevice_handler;../../../../../../components/softdevice/s132/headers;../../../../../../components/softdevice/s132/headers/nrf52;../../../../../../components/toolchain;../../../../../../components/toolchain/CMSIS/include;../../../../../../external/segger_rtt;../../../../../../examples/bsp;../../../../../../examples/ble_peripheral/ble_app_beacon/config/ble_app_beacon_s130_pca10028;../config"
      debug_additional_load_file="/Users/red/Desktop/nRF5_SDK_11.0.0_89a8197/components/softdevice/s130/hex/s130_nrf51_2.0.0_softdevice.hex"
      linker_section_placement_macros="FLASH_START=0x1B000;SRAM_START=0x20002500"
      linker_section_placements_segments="FLASH RX 0x00000000 0x00040000;SRAM RWX 0x20000000 0x00004000"
      supplyPower="Yes" />
  </project>
  <configuration Name="Internal" hidden="Yes" />
  <configuration
    c_preprocessor_definitions="NRF51"
    inherited_configurations="Internal" />
</solution>
оно все собирается, но при этом рабоать толком отказывается - уходит в hardfault. при этом как в отладчике сеггера понять, откуда и почему оно туда попадает - не ясно. у меня есть сомнения в том, что я правильно указал циферки с областями памяти для линкера.
плюс на сайте нордика есть заметка про то, что надо править файл thumb_crt0.s (кстати, какова его роль в сеггере?)
https://devzone.nordicsemi.com/question ... t-id-68736
ничего не понятно, что там нужно было делать. но у меня и той ошибки не выскакивало - поэтому я ничего не трогал (и возможно зря).
