Текущее время: 28 янв 2021, 13:31
 Заголовок сообщения: ESP 32 настроить передачу CAN на 10kb
СообщениеДобавлено: 20 дек 2019, 23:52
Скачал библиотеку для работы c CAN шиной. на 100kb работает без проблем а на 10kb работать не хочет, в инициализации частоту делил на 10 эффекта нет
int CAN_init() {
   // Time quantum
   double __tq;
   // enable module
   DPORT_SET_PERI_REG_MASK(DPORT_PERIP_CLK_EN_REG, DPORT_CAN_CLK_EN);
   DPORT_CLEAR_PERI_REG_MASK(DPORT_PERIP_RST_EN_REG, DPORT_CAN_RST);
   // configure TX pin
   gpio_set_level(CAN_cfg.tx_pin_id, 1);
   gpio_set_direction(CAN_cfg.tx_pin_id, GPIO_MODE_OUTPUT);
   gpio_matrix_out(CAN_cfg.tx_pin_id, CAN_TX_IDX, 0, 0);
   gpio_pad_select_gpio(CAN_cfg.tx_pin_id);
   // configure RX pin
   gpio_set_direction(CAN_cfg.rx_pin_id, GPIO_MODE_INPUT);
   gpio_matrix_in(CAN_cfg.rx_pin_id, CAN_RX_IDX, 0);
   gpio_pad_select_gpio(CAN_cfg.rx_pin_id);
   // set to PELICAN mode
   MODULE_CAN->CDR.B.CAN_M = 0x1;
   // synchronization jump width is the same for all baud rates
   MODULE_CAN->BTR0.B.SJW = 0x1;
   // TSEG2 is the same for all baud rates
   MODULE_CAN->BTR1.B.TSEG2 = 0x1;
   // select time quantum and set TSEG1
   switch (CAN_cfg.speed) {
   case CAN_SPEED_1000KBPS:
      MODULE_CAN->BTR1.B.TSEG1 = 0x4;
      __tq = 0.125;
      break;
   case CAN_SPEED_800KBPS:
      MODULE_CAN->BTR1.B.TSEG1 = 0x6;
      __tq = 0.125;
      break;
   case CAN_SPEED_200KBPS:
      MODULE_CAN->BTR1.B.TSEG1 = 0xc;
      MODULE_CAN->BTR1.B.TSEG2 = 0x5;
      __tq = 0.25;
      break;
   default:
      __tq = ((float) 1000 / CAN_cfg.speed) / 16;
   // set baud rate prescaler
   MODULE_CAN->BTR0.B.BRP = (uint8_t) round((((APB_CLK_FREQ * __tq) / 2) - 1) / 1000000) - 1;
   /* Set sampling
    * 1 -> triple; the bus is sampled three times; recommended for low/medium speed buses     (class A and B) where
    * filtering spikes on the bus line is beneficial 0 -> single; the bus is sampled once; recommended for high speed
    * buses (SAE class C)*/
   MODULE_CAN->BTR1.B.SAM = 0x1;
   // enable all interrupts
   MODULE_CAN->IER.U = 0xff;
    // Set acceptance filter
   MODULE_CAN->MOD.B.AFM = __filter.FM;
    MODULE_CAN->MBX_CTRL.ACC.CODE[0] = __filter.ACR0;
    MODULE_CAN->MBX_CTRL.ACC.CODE[1] = __filter.ACR1;
    MODULE_CAN->MBX_CTRL.ACC.CODE[2] = __filter.ACR2;
    MODULE_CAN->MBX_CTRL.ACC.CODE[3] = __filter.ACR3;
    MODULE_CAN->MBX_CTRL.ACC.MASK[0] = __filter.AMR0;
    MODULE_CAN->MBX_CTRL.ACC.MASK[1] = __filter.AMR1;
    MODULE_CAN->MBX_CTRL.ACC.MASK[2] = __filter.AMR2;
    MODULE_CAN->MBX_CTRL.ACC.MASK[3] = __filter.AMR3;
   // set to normal mode
   MODULE_CAN->OCR.B.OCMODE = __CAN_OC_NOM;
   // clear error counters
   MODULE_CAN->TXERR.U = 0;
   MODULE_CAN->RXERR.U = 0;
   (void) MODULE_CAN->ECC;
   // clear interrupt flags
   (void) MODULE_CAN->IR.U;
   // install CAN ISR
   esp_intr_alloc(ETS_CAN_INTR_SOURCE, 0, CAN_isr, NULL, NULL);
   // allocate the tx complete semaphore
   sem_tx_complete = xSemaphoreCreateBinary();
   // Showtime. Release Reset Mode.
   MODULE_CAN->MOD.B.RM = 0;
   return 0;
 Заголовок сообщения: Re: ESP 32 настроить передачу CAN на 10kb
СообщениеДобавлено: 21 дек 2019, 11:23
А спецификации ESP32 какую минимальную скорость обещают?
Есть вероятность, что и MCP2551 на 10кб/с не будет работать.
Everybody lies
СообщениеДобавлено: 21 дек 2019, 12:19
Stm32f103 и Mcp2551 работают замечательно на 10kb
СообщениеДобавлено: 21 дек 2019, 14:10
А ESP32?
Everybody lies
СообщениеДобавлено: 21 дек 2019, 17:05
Не настроите. Делитель получается больше 2^8. А регистр 8-битный...
Последний раз редактировалось Z_A 21 дек 2019, 17:11, всего редактировалось 1 раз.
СообщениеДобавлено: 21 дек 2019, 19:50
что-то в reference manual про CAN ничего не сказано. Проц больше 200МГц а регистры 8бит. фигня какая то
СообщениеДобавлено: 21 дек 2019, 20:00
Ага. Сам хотел полтора года назад беспроводной шлюз сделать, надо было 16 кбит скорость. А фигвам.
Делал по примерам, когда не взлетело, стал ковырять, нарыл короткий регистр. Его хватает на 40 с чем-то килобит. Меньше нельзя.
СообщениеДобавлено: 21 дек 2019, 21:26
а случайно не шлюз MQTT-CAN?
СообщениеДобавлено: 21 дек 2019, 23:21
ну по мануалу минимальная частота 80МГц / 256 / 25 (TSEG1=16 + TSEG2=8 + 1sync) = 12500.
СообщениеДобавлено: 22 дек 2019, 00:46
А как тогда настроить делитель? Почему то ниже 50kb ничего не работает.
СообщениеДобавлено: 22 дек 2019, 09:42
Регистры TSEG1 и TSEG2
СообщениеДобавлено: 22 дек 2019, 11:56
MODULE_CAN->BTR1.B.TSEG1 = 15; это максимум если 16 то компилятор ругается
MODULE_CAN->BTR1.B.TSEG2 = 7;это максимум если 7 то компилятор ругается
MODULE_CAN->BTR0.B.BRP = тут что должно быть ?
СообщениеДобавлено: 22 дек 2019, 12:20
С помощью дедуктивного метода предположу что 255, ведь на 256 компилятор заругается.
СообщениеДобавлено: 22 дек 2019, 20:03
дедуктивный метод для ардуино не работает. не дает записать больше 63 выдает компилятор ошибку
warning: large integer implicitly truncated to unsigned type [-Woverflow]
СообщениеДобавлено: 23 дек 2019, 13:23
Ну хз, документации человеческой нет, видел описание что делитель от 1 до 256 с шагом 4, возможно под этим этот 6ти битный регистр и подразумевался.
СообщениеДобавлено: 23 дек 2019, 21:56
такой процессор, а нужен для мигания светодиодом
